When I received them the fit and finish was good and the attention to deal was great. The next to skin feel was great. I like to bonded check pocket as it has not started to peal like my UA gear. The thickness is a little thicker than some base layers but not too hot. It is ment to be a tight fitting piece of clothing. Now for the testing part.
Have worn this top from the 30′s to the 70′s and it has done a great job regulating my temp. The Dry Zone material is tight woven and does a pretty good job keeping the wind out so that chill is almost nonexistent. When I am outside is 30* weather and then get in the car or house, I still leave the top on and I am not getting hot to wear I am sweating. I stay at a comfortable temp. When I leave in the mornings and there is a slight chill in the air I will wear the lg as a mid layer and forget that I have it on later in the day when it has warmed up to the hight 60′s low 70′s. Now I can see how my Sherpa rep wears this top skiing. I wear this for a week and then I will wash it and with the silver ions it does not start to smell like some other clothing that I have worn.
Pros: Light weight, can be worn as a base layer or mid layer, breathes exceptional well, quick drying, warm and Great in different temp ranges.
Cons: There is none!
This is the info about the Tsepun top:
Designed specifically for Sherpa Adventure Gear, our stateof-the-art Dry Zone® “intelligent” fabric is fast wicking and dries incredibly quick. And thanks to its high-tech, thermal conductivity control, it will keep you toasty warm. If you plan to invest in just one warmer base layer this year, this is it.
Blocks 99% of UV rays so you don’t get burned at high elevations
So light in weight, it floats
Woven with anti-bacterial silver ions to minimize odors
Raglan sleeves have flat-locked seams to reduce the chafing that can occur under packstraps
Fabric: 82% nylon / 18% polyester
SP12343 | S-XXL | 250 g. (8.8 oz.)
