Natural Turkey Feather Fletching
Postby rancid crabtree » Tue Jan 27, 2009 8:18 pm
I use the feathers from the birds we harvest to make my own arrow fletchings. I make the c0ck feathers from the wings of turkeys that I harvest. I am a traditional archer and bowhunter and I make all my own equipment.
I like to use whole uncut white feathers for the two hen feathers and a homemade c0ck feather. I found 7 good looking specimens (one is a spare)
Next I split them to get rid of the side that I won’t need.
Then I find the best section in the middle of the length and cut off the ends. These are longer than I need but I will trim them later
Because the split base is way to thick I need to thin them down.
I use a belt sander with a fine grit belt because the bases are pretty soft. I finish them with a sanding block
The thined feather is a lot less beefy.
Next I cut them to their finished length.
After fletching, I use a feather burner to give them their shape.
Re: How to recycle a turkey and make it fly again
Postby born2hunt » Tue Jan 27, 2009 9:08 pm
Good info Rancid!
What do you use to split them with? A razor-knife?
Ken
born2hunt
Postby rancid crabtree » Tue Jan 27, 2009 9:12 pm
A regular old Stanley construction razor blade knife.
Postby BowHuntingFool » Tue Jan 27, 2009 9:14 pm
Good one RC, I just made some flu flu arrows last week from the feathers of my spring tom! I did the spiral fletch, worked pretty smooth!
>>>---Joe---->
WhisperStik VoodooStik 58", 50#
Montana Longbow 64", 50#
Mohawk Longbow 64", 52#
Lyman .54 Deerstalker Flintlock
Lyman .50 GPR Flintlock
NRA Member
BowHuntingFool
Postby TradRag » Tue Jan 27, 2009 9:40 pm
This is GREAT :!: Too bad I left last springs right wing on top of the Truck last year when I left camp. Thought about it 2 ours later when I started to unpack!!! ROAR! I'll have to try again this year.
Postby Buddy Bell » Tue Jan 27, 2009 11:56 pm
Good stuff RC. I hook up a 12V battery charger to each end of my wire and it turns red quick. No blown fuses either.
What kind of weight (3#) do you use for your spine tester? I have fish weights but they are too bulky and not accurate enough.
Trad is 75% mental & 25% mental ))))====> Buddy Bell
Buddy Bell
Re: Natural Turkey Feather Fletching
Postby TradRag » Thu Jan 28, 2010 9:44 pm
got more feathers on the way!!!
Postby Cyclic-Rivers » Wed Feb 03, 2010 9:15 pm
Great thread. Hope to be making some of my own soon. Perhaps I can practice on found feathers. ;)
Cyclic-Rivers
Postby zeek from coon creek » Sun Dec 06, 2015 9:33 pm
I know this thread hasn't been active for a long time but I have a couple of qustions about the feather burner. Is it home made? Did you build it? If so, would you show us how. I have Young burner but yours looks way more user friendly in the way the arrow is supported.
Users browsing this forum: Google [Bot] and 8 guests
