Abowyer, Inc.
Help Support TradRag by visiting its Sponsors. Thank you!
Abowyer, Inc.
Postby TradRag » Thu Jan 17, 2013 1:18 pm
Abowyer, Inc.
Visit us TODAY!! http://www.abowyer.com
Display
Abowyer Broadheads Provide These Great Features:
* Cut On Contact Tanto Tip
* 25 Deg Bevel
* .072 Thick Blade
* Cryogenic Tempering
* 1075 Cutlery Grade High Carbon Steel Blade
* 52 Rockwell Hardness
* Teflon-Molly Baked On Coating
* Resistance Welded and Copper Brazed
* Ferrule Is CNC Machined From Solid Bar Stock
* Trailing Edge Bevel Resists Arrow Backing Out Of Wound Channel
* 25 Deg Bevel Creates Ferrule Clearance For Sharpening
* Single Bevel Compounds The Arrows Rotation Upon Penetration For Better Bone Splitting
* “S” Cut Creates A Larger Wound Channel
* Positive Lead Cutting For The Most Efficient Use Of Energy Available
* Rotation Eliminates Friction On One Side Of Blade Increasing Penetration
* Use In Conjunction with Tapered Adaptors to Achieve Weights From 160 To 335 Grains
* Lifetime Guarantee
Brown Bear
Last bumped by TradRag on Thu Jan 17, 2013 1:18 pm.
Return to Our Sponsors
