2016 Archery Bear hunting blog (the home made edition)
Post your stories, pictures and experiences of Big or Small Game harvest.
Postby rancid crabtree » Mon Apr 04, 2016 8:31 am
I'll use this space to keep a journal now that Ive drawn a WI fall bear tag. I will be hunting zone D with Northern Bayfield County Guide Service
I plan to hunt with a bow and arrow as I have no interest in hunting bear with a firearm. Im leaning towards using a traditional bow and most likely one Ive made myself. I plan to make my own broadheads and arrows as well as other homemade items for this hunt. Ive taken deer with all homemade gear but Ive not taken a bear so here's my chance. I have 6 months to prepare. I will chronicle all of that here.
Re: 2016 Archery Bear hunting blog (the home made edition)
Postby rancid crabtree » Mon Apr 04, 2016 8:32 am
Im making a new set of single bevel broadheads the upcoming WI bear hunt. Im planning on using field points and 7 1/4" circular saw blades for the main blade. Im slotting the field tip (ferrule) and can peen the tip of the ferrule onto the blade but the joint at the back end is more challenging.
Over the weekend I starting messing around with a prototype. Now Im thinking of instead, using a threaded adapter rather than a reshaped field point.
Beveling made easy with the right tool for the job. I get to use my own product.
https://www.youtube.com/watch?v=OmJW7zdfiR4
Postby rancid crabtree » Mon Apr 04, 2016 8:34 am
The field points are steel and heavy. I wanted a little lighter version for the bear hunt broadhead so I switched from the re-shaped, steel, field points to aluminum adapters.
Since they are aluminum I can use a micro saw and a Dremmel tool to cut the slots.
Then it was back to the saw blade
I used my broadhead sharpening guide to make the single bevel.
I will use J.B. Weld in the slot cut in the adapter to fuse the blade and I will peen over the tip of the adapter in the hole in the blade to further trap the blade on the adapter. The J.B. Weld and eventual paint will have the final broadhead around 180 grains.
Here is a video of the fit up before fusing the parts.
https://www.youtube.com/watch?v=Y0GNV9IzqcE
Postby rancid crabtree » Wed Apr 06, 2016 6:37 am
The first head is fused to the threaded adapter with J.B. Weld and by peening the tip closed in the hole in the blade. Then it was primed and painted.
In the universe of possible colors for broadheads, Ive always felt that glossy plum has been under-utilized. I hope to rectify that. Who knows, it might catch on. I took an indoor and an outdoor photo and you would think they were two different broadheads based on how the colors seem to have changed based on the lighting.
I calculated exactly just how much J.B. Weld and how much purple paint would be needed to get the head to exactly 180 grains....................... Nah, I just got lucky. The goal was 180 grains but I didn't think I would hit it spot on. Its better to be lucky than good. Now I just need to make a few more.
Postby zeek from coon creek » Wed Apr 06, 2016 5:38 pm
Very impressive. You are right about the color thing. If you hadn't said otherwise I'd have thought one was painted blue and the other purple. I'm looking forward to seeing the rest of your gear for this hunt develop.
Postby Wind D Ranch » Sat Aug 06, 2016 8:29 am
Nice work. Best of luck on your hunt and thanks for taking us along.
NRA Life Member
"Magna est veritas sed rara" (Archers are all honorable men) The White Company by A. Conan Doyle
Thanks for everything, dad.
Wind D Ranch
Postby rancid crabtree » Tue Sep 06, 2016 6:54 am
The archery bear hunt is fast approaching. In a little over a week, I make the trek to far Northern Wisconsin near the town of Cornucopia just south of Lake Superior's Squaw bay.
I will be hunting with Art Hyde of Northern Bayfield County Guide service. Over the summer the focus has been on practice.
Now the camo has been washed in baking soda and when dry will be placed in the homemade ozone locker.
More practice and then the homemade broadheads will be rehoned with the homemade broadhead sharpening guide. The countdown clock is ticking fast now. The season (for me) opens on Sept 12th.
Postby rancid crabtree » Tue Sep 13, 2016 11:49 am
The bear hunt was short and sweet (almost too fast) I just dropped off both of my bear at the Butcher. Normally I would do them myself but Im 5 hours from my home butcher shop.
Interesting and exciting story on how I ended up killing two bear. Im putting together a video with pictures and video explaining.
Postby rancid crabtree » Tue Sep 13, 2016 8:55 pm
Postby Wind D Ranch » Thu Sep 15, 2016 7:27 pm
Congratulations and great shot! It sounds like you have plenty of bear meat for a while. :applaud:
NRA Life Member
Wind D Ranch
Postby rancid crabtree » Sat Sep 17, 2016 8:14 pm
I have not missed an archery deer opening day in a long time but because I have two bear to deal with I had no choice. Friday night, the meat was thawed enough to work with so I began cutting and trimming. I also began the process of doing Euro mounts on both skulls as well as salting the smaller (truck killed) bear skin. The other skin is in the freezer for my Nephew.
On Saturday I completed the cutting and wrapping of the meat. I kept the lions share for sausage making but saved some roasts, steaks, loins as well as cubed meat for stews and chili. Later on I will make snack stick and perhaps summer sausage.
I got all the meat off the skulls and applied 40 volume whitener and the skulls will now sit for a few days until I rinse them.
Then I turned my attention to the small hide. Im thinking of tanning it myself and perhaps making a quiver or hat or gloves so I cut off the remaining front feet and the head. (I will harvest the claws at a later date so the feet went to the freezer) The hide sat salted for 24 hours then I rinsed it and fleshed it out. I use a piece of PVC as a fleshing beam.
Here is the hide after all the flesh and fat and membrane are removed. The prime areas of the hide really stand out (dark blue area)
Then I salted it again.
Tomorrow I will rinse off the salt and twice bathe the hide in hot water with Dawn dish soap to degrease it and then rinse and hang it.
Postby rancid crabtree » Sun Sep 18, 2016 6:41 pm
6 Days since the hunt and I got both skulls cleaned and the first whitening completed. The hide is still under salt.
Return to Other Hunting | Big and Small | Hogs
